Can't filter date by field in new map viewer?
1198
07-08-2021 02:31 PM
ChelseyDesautels
Hello,
In map viewer classic I was able to filter a date field based on another date field:
I am not finding this option in the new map viewer.
Can you filter a date by field somehow or does it have to be by a value?
Thanks.
Tags (1)
RussRoberts
Esri Notable Contributor
We currently do not have filtering between 2 fields in the filter experience in ArcGIS Online.  Right now its only through value.
ChelseyDesautels
Thank you for the response.
Will the option to filter between two fields be added in the future at all?
tmichael_wpjwa
I also have a use case where I'd like to filter using two date fields in the same feature layer.  Will this functionality be coming to the new map viewer in an upcoming release?
RussRoberts
Currently not planned for any upcoming release but recommend creating an ArcGIS Online idea if one does not exist and we can track it.
