Can I create a select by attributes tool in ARCGIS Online?
3317
10
06-15-2014 09:20 PM
TaylorLundeen
I am trying to figure out if and how I can create a select by attributes tool for a map service within ARCGIS Online, since the tool is not available on that program. I was wondering if there is a script I could run in the API that would do this, or if I could somehow incorporate python script into ARCGIS Online, since I know the python code to run a selection by attributes.
JoeFlannery
Honored Contributor
Taylor:
Two things come to mind.  In #8 of this thread, you mention uploading data from ArcMap to AGOL using "Add Layer from File".  I'm not sure what that means.  Try pushing your ArcMap data to AGOL via >File >Share As >Service.  The result will be a Hosted Feature Service.
[ATTACH=CONFIG]34643[/ATTACH]
Secondly, not every layer "Type" in the table-of-contents of an AGOL map is able to have its attribute table exposed or filtered.  See my capabilities table, below.
[ATTACH=CONFIG]34644[/ATTACH]
