Calculate area of polygon I draw
4961
6
06-20-2021 08:19 AM
BetsyMacWhinney
I'm a newish/beginning user, and I'm trying to calculate the area of a polygon I draw using map notes.  I understand that I can use the measurement tools to measure after I've drawn, but this is extra work and clunky, in that I have to somehow record the area  manually after I've measured.
I am trying to analyze landuse types within several 1K circles, and each may contain several different land uses that I outline with map notes.    I would love to be able to click on each of the polygons I draw and have it show the area and also be able to add that to the legend.
Thanks for any tips!
Tags (1)
2 Solutions
JayantaPoddar
I would recommend creating an empty shapefile with desired schema (ArcGIS Desktop or QGIS), and uploading it to ArcGIS Online (if not publishing it from ArcGIS Desktop), thus creating a hosted feature layer.
You can edit the hosted feature layer, creating polygons and adding desired attributes along with the calculation of area and length of polygons.
Think Location
DavidPike
MVP Notable Contributor
Depending on your privileges on ArcGIS Online, Go to you 'Content'  --> 'Create' (near the top left) --> 'Feature Layer' --> 'Build a Layer' --> 'Polygons' then use that as the hosted feature layer for editing.
JayantaPoddar
Think Location
BetsyMacWhinney
Thank you! I don't have ArcGIS Desktop or QGIS but maybe I should look into QGIS.  Appreciate your help!
DavidPike
BetsyMacWhinney
Thanks! This gets me a lot closer.  I do have the necessary permissions to create a feature layer.  I'm a little unclear on how to calculate the area of the polygon I created in this fashion.  Thanks so much for your time.
JayantaPoddar
That's a really good method mentioned by David. In case you have chosen "Build a Layer" > Polygons from the templates, Shape_Area and Shape_Length fields are already available (These fields are automatically calculated). You just need to show those fields in attribute table.
You could also Show the Field from Item Details page of the Hosted Feature Layer (Data tab > Table).
In case you see blank pop-up of Shape_Area while creating the shape, keep it blank and close. It will be calculated automatically.
Think Location
DavidPike
I should also say that these areas are almost useless as the shapefile is created in web mercator.  I'd recommend creating a new attribute expression where:
AreaGeodetic(geometry($feature), 'kilometers')
