AUTOCAD TO ARCGIS ONLINE
587
05-11-2019 02:48 PM
LameckOmondi_Omolo
Hi, i am trying to extract some data from AUTOCAD to shapefile then zip them before uploading them to arcgis online. Unfortunately i get an error "UNABLE TO IMPORT THIS SHAPEFILE". When i look at my files i have 6 files not 7 then realized that i lack the .prj file, could this be the reason and why is it that when I export the features to shapefile i do not get this .prj file?
Regards
LAOM
Katie_Clark
MVP Regular Contributor
I'm not completely sure, but it's a good guess that not having the .prj file is why you're having trouble with ArcGIS Online...did you set a spatial reference to the layer(s) in ArcMap?
If not, I would suggest doing that and then try publishing again....does that work?
Best,
Katie
“The goal is not simply to ‘work hard, play hard.’ The goal is to make our work and our play indistinguishable.”
- Simon Sinek
