Array of Addresses - popup expression
152
02-14-2025 07:45 PM
VirginiaRobenski
I am working in on a Portal map, creating a pop-up.
I have an array of addresses.
Each address varies in lengths, and some have blanks I'm trying to remove.
I am trying to loop through the Array and remove all empty elements.
Anyone have suggestions on how to do this? I can't seem to get it to work with IsEmpty and Erase
gis_KIWI4
@VirginiaRobenski - Are you able to share the arcade code?
We have used IsEmpty() and it works.
Also when you say you can't get it to work, is it the pop up that doesn't work or code fails to remove the blanks?
KenBuja
And it would be helpful to see how your data is formatted and what you'd like the output to look like.
