Are you able to edit a cloned hosted feature service?
442
09-06-2019 02:52 PM
KevinKozak
Hello,
I am trying to create a new version of my bridge inspection data by using the python API. I have cloned the feature service and added a new field and domains using the API. However, I am not able to edit the cloned feature service. To see if my edits were causing the problem, I cloned again and tried edit but still couldn’t. Are you able to edit cloned data in ArcGIS Online?
I am receiving the following web map error when editing. “Error Accessing data failed”.
Looking at sentences being passed I see the following.
This is what was passed in from my edit:
[{"attributes":{"OBJECTID":107,"brdg_nm":"KELLOG BRIDGE (16)","brdg_no":"1233477","road_nm":null,"road_no":null,"milepost_no":null,"location_id":"T11R38E-2","stream_nm":null,"gis_long_dd":-118.069024618766,"gis_lat_dd":46.4330625042863,"region_cd":100,"strc_serial_no":null,"oper_lvl_cd":null,"design_load_invt":97,"design_load_oper":97,"oper_rate_tons":null,"invt_rate_tons":null,"brdg_open_flg":null,"brdg_posted_flg":null,"severity_rating_cd":null,"fracture_crit_flg":null,"brdg_priv_flg":null,"brdg_cost_share_flg":null,"replacement_yr":null,"superstruct_ty":8,"superstruct_mat_ty":5,"substruct_ty":99,"deck_ty":"1","wear_surface_cd":"1","strc_lng":31,"max_span_lng":null,"curb_curb_wd":26,"out_out_deck_wd":null,"approach_rdway_wd":null,"brdg_yr_built":null,"brdg_note":"GOOD","symbl_rotation":null,"brdg_guid":"3925b5a1-5e1a-4fd1-9ee0-fd0a6723273d","globalid_agol":"3925b5a1-5e1a-4fd1-9ee0-fd0a6723273d","brdg_yr_rebuilt":null}}]
Here’s the error:
,"error":{"code":1000,"description":"Invalid object name 'user_349.wadnr_bridge_service_20180324_8468ed444593473da02d3e7cc1250082_STATE_LANDS___BRIDGES__tracking'."}}],"
Thank you for your help.
Kevin
MarisaClaggett
Occasional Contributor II
Hi Kevin,
How are you cloning the hosted feature services?  Are you creating hosted feature layer views?  What is the code you use?
If using views, you will need to make the view editable as well, assuming the original hosted feature layer is set to be editable as well.  Let me know if you have the code snippet!
Best of luck,
Marisa
KevinKozak
Hello Marisa,
Thank you for your reply. I have been trying to attach my jupyter notebook but can't find the paper clip. So I have copied the code I am using to clone. Sorry about that.
## clone_bridge 9/3/2019
## Kevin Kozak
## Clones the Bridge collection to new version.
## Input: WADNR Bridges DEMO Version 1
## Output: WADNR Bridges DEMO Version 1 in different folder
# In[ ]:
import arcgis
# In[ ]:
from arcgis.gis import GIS
# In[ ]:
from arcgis.features import FeatureLayerCollection
# In[ ]:
# In[ ]:
gis = GIS("https://www.arcgis.com", username = "KEVIN.KOZAK")
# In[ ]:
print("Logged in as " + str(gis.properties.user.username))
# In[ ]:
# bridge demo item
service_item = gis.content.get("c1088872854444a1a472b471ef383f33")
# In[ ]:
service_item
# In[ ]:
service_item.layers
# In[ ]:
itemsArr = [service_item]
# In[ ]:
itemsArr
# In[ ]:
gis.content.clone_items(itemsArr, folder="SurveyWaDNRBridgeInspeBunk", copy_data=True)
