I was wondering if it was possible to set attachments for features where users can edit one set of attachments while preserving another set of attachments for the sane feature(s). So for instance, I have documents that I want to keep attached to a feature bit I want to enable the user(s) to be able to add photos. I don't know if this is possible but I was wondering if anyone has ever done this or knows how to do it. If anyone wouldn't mind letting me know I'd greatly appreciate it.
Robert
One way you can achieve this is through enabling ownership-based access control (OBAC) on this feature service.
Assume you have feature F + attachment (A1). If userA owns this feature F + A1, then no-one will be able to delete or update this attachment (A1) if you enable OBAC.
So you will define ownership-based access control like below. Your users can add attachment only and cannot delete or update existing one including the one they add.
"editorTrackingInfo" : { "enableEditorTracking" : true, "enableOwnershipAccessControl" : true, "allowOthersToQuery" : true, "allowOthersToUpdate" : false, "allowOthersToDelete" : false }
Not sure if you need your client to modify existing attachments. If you do, then we do not really have a solution for this and you might need to enforce this in the app side but still the client will be able to go and bypass the client side modify or delete this attachment you do not want them to change.
Thanks
Khaled Hassen
Online Feature Service Lead
That sounds close to what I was looking for. I was also wondering if you
could control who can add, update, and delete attachments using versions
and only enabling certain users to add, delete, and update a version that
only they have access to. Is there a possibility of creating two related
tables and synchronize one set of attachments and keeping another constant?
Just curious if this is possible or not. I'll try your method and see how
that works out.
Robert
Not for the same feature. We do support creating views that you can allow your clients to view attachments only or not seeing attachment at all. But for the same feature, we do not have a solution for it currently.
Thanks
Khaled
Is it possible to have attachments and related tables simultaneously or is
that not currently possible?
Yes you can. So you can have layer A + attachment + related table to layer A
Ok I might try that instead so the documents that I upload can still be
viewed and the user(s) can add attachments without deleting the documents.
