ArcGIS Popup Window will not display Attribute data.
2622
11-23-2011 07:21 AM
GregDexter
I have Map Service hosted on our ArcGIS Server. I am using the map service in the ArcGIS.com map viewer. All of the features are displayed properly on the map however when I configure a point layer to display a Popup window the window returns "No Information Available".
I checked the ArcGIS Server Logs and found the following error.
<Msg time='2011-11-23T11:43:39' type='ERROR' code='10837' target='Projects/MtAiry_MapServiceV3.MapServer' machine='rkk38' process='6316' thread='2676'>GeoDatabase Error :Only one spatial column is supported in this operation[MTAIRY.WA_VALVE][STATE_ID = 13750].</Msg>
<Msg time='2011-11-23T11:43:39' type='ERROR' code='100005' target='Projects/MtAiry_MapServiceV3.MapServer' methodName='MapServer.QueryFeatureData' machine='rkk38' process='6316' thread='2676' elapsed='0.00817'>Method failed.HRESULT = 0x8004158a : This is a FACILITY_ITF error that is specific to the interface that returned this error. See the documentation of the interface that returned this error for information about this HRESULT.</Msg>
Theres is only one spatial column. The Features are stored in an ArcSDE Oracle database has anyone run into this problem?
MikeMinami
Esri Notable Contributor
Can you share the REST URL to your map service? And also indicate which point layer has the issue?
Mike
GregDexter
THanks for the reply...
The rest url is:
http://apps.rkk.com/ArcGISServer/rest/services/Projects/MtAiry_MapServiceV3/MapServer
It seems that none of the layers will display popup information.
MikeMinami
Queries sent to your map service are failing. I believe it's a problem with ArcGIS Server. You are running an older version (9.3). Here's another forum posts that discusses this error.
http://forums.arcgis.com/threads/42305-Cannot-get-pop-ups-to-work?p=145731&viewfull=1#post145731
The solution, I believe, is to upgrade your server to ArcGIS Server 9.3 SP1.
Mike
