ArcGIS Online Web Map - Search by Layers not Showing Field in Dropdown
1543
05-30-2024 01:28 PM
a_bakiera
Hello. I am trying to set up the Search by Layers feature within a webmap in ArcGIS Online. I am not able to see one of the fields I am trying to set up. Is there something that needs to be configured for each field in order for it to be able to be searched? This thread https://community.esri.com/t5/arcgis-online-questions/cannot-search-multiple-fields-for-hosted-featu... has a similar issue so wondering if this is just another bug.
Field not seen in dropdown below
 Thanks!
RussRoberts
Esri Notable Contributor
The field type needs to be integer or string. Domains also cannot be used on the fields.
https://doc.arcgis.com/en/arcgis-online/create-maps/configure-feature-search.htm
RussRoberts
a_bakiera
Thank you! I missed that document when I was looking this up. Do you know if fields other than integer or string will be supported in the future?
RussRoberts
Currently nothing on our roadmap to expand this out. The next steps for this will be to bring the experience into Map Viewer where you can build and test/use the search without having to go to the settings on the item.
