ArcGIS online Web AppBuilder for ArcGIS print not working
6313
9
10-20-2014 08:24 AM
CharlesDawley
topic says it all.
Here is my sample map
ArcGIS Web Application
Print hangs and says "Error, try again"
CharlesDawley
Also not working here.
It will hang and say "Error, try again"
I am using Firefox and Chrome
MikeMinami
Esri Notable Contributor
I did see some the request timing out. However, it should be working better now...
Mike
by Anonymous User
Not applicable
Does anyone know which files I need to update the serviceURL for the printer service used? I want to change the URL back to the default AGOL print service (Task: Export Web Map Task) . I updated the Print widget's config_Print.json file inside my app, but are there other locations where I need to change it as well?
BillKnipp
Mine is still saying error try again.  It has worked a couple times (which does not make alot of sense) but most times it says error try again.  Is there anything I can do to improve it.
by Anonymous User
Not applicable
It seems to be wonky in general. As long as I have it set to the default AGOL print service it works, most of the time. Not sure if this will help, but I would suggest changing the default DPI under Print Quality to 150 or so when you print, I don't think the 300 is needed.
CharlesDawley
Having problems printing. again.
Hunting Form | Little Traverse Conservancy
Seems to error out alot. Makes things very frustrating for users.
JeremyNicolay
I have exactly the same problem. Any idea how to fix this?
Ben Gardner​ : I tried to reduce the printing quality but nothing changed.
JessicaGooch1
I am also having the same issue...
CharlesDawley
sometimes if you clear your browser cache it works better.. but not all the time.. its a pain that ESRI should really fix. My users complain to me on a regular basis..
