ArcGis Online - PopUp troubles
2701
12-17-2015 03:38 AM
OscarDiago
I can't make my PopUps pop.
My client sent an ArcGIS Service to make a map in ArcGis Online. I added it to the map and enabled the pop-up window. When I clicked on an element, all the information appeared in the pop-up. That's the behaviour I was expecting (and the one explained in every guidebook).
But the client decided to create a new service to include more fields (making a join with another table). I created a new map with the new layer and enabled the pop-up window. But now, every time I click on a element the only thing I get is a pop-up window with the following message: "No information found". So, I have checked the Attribute Table of the service and all the data is there.
This is the request I have captured when I click on an element:
http://myAOL.maps.arcgis.com/sharing/proxy?http://theserver.ddd.es/arcgis/rest/services/mylayer/MapS...
In the old service, the request was this one:
http://theserver.ddd.es/arcgis/rest/services/myOLDlayer/MapServer/0/query?f=json&returnGeometry=true...
Why that proxy part in the new one?? I don't understand!!
Some differences between the two services my client has pointed out:
- The new one has Joins
- The new one is WMS, but not the other one
- The old one had the table attached. In the list of layers, appart from the layer, it also appeared the table. In the new one it only appears the layer.
- In the new service, the options Supports Advanced Querie and Supports Statistics are false. In the old one they were set to true.
Does anyone have a clue what is going on with the new service?
Thank you!!
Tags (1)
RussRoberts
Esri Notable Contributor
Hey Oscar,
Pop-ups for OGC WMS and OGC WMTS are not supported.
Cheers
Russ
RussRoberts
Hey Oscar,
Cheers
Russ
OscarDiago
Thank you so much!! I forgot about that!!
