ArcGIS Online - Need to prevent users from zooming in too close or out too far
14970
18
06-17-2016 07:51 AM
RayCrew
I have not found a way in ArcGIS OnLine Web Mapping Applications nor Web Maps to limit how far users can zoom in or out. It is possible if there is a cached base map, but not otherwise. Setting scale dependencies and limits on REST services and layers does not negate this need. That will stop the layers from being displayed, but still allow scales that may cause users confusion, frustrations, and problems. Setting a default scale and extent will also fail to address this. This function was possible in an older ESRI platform, ArcGIS for Flex, by specifying LODs.
Does anyone know if this is possible?
Example of my user's problems:  Have a global map showing total population by country. The current setup allows a user to zoom in very tight (like to 1:1,147) of automatically zooms to such a scale after searching for a point location. At that scale the user will most likely be deep inside one country's polygon requiring them to have to pan and zoom back out many times to see another country to compare to.
RayCrew
Hi Kelly:
Jake's idea above only works with cached data. I consider that an oversight on ESRI part, but that is the way it is.  I still need to have user zoom in to different levels, so cutting it out completely will not work. And presentations will not work as navigating around the map and exploring the data is too important.
And on the idea to support, I am the one who submitted that. The only support so far has been me, so let me petition to you to vote it up.
Raymond
RayCrew
Please folks, go vote my idea up.
https://community.esri.com/ideas/12160
by Anonymous User
Not applicable
I found a confirmed / Reproducible bug with AGOL.  I had the build a fresh webmap from a service and a vanilla WAB hosted online all on AGOL.  The limiting of zoom out to max scale doesn't work.
The reference number for the bug is BUG-000099639: Setting custom visible scales in ArcGIS Online Web App Builder fails when you remove scale values of 591,657,527.591555 ; 295,828,763.795777 and 147,914,381.897889.
RayCrew
Kevin. I do not think this has anything to do with this topic. Honestly I am not sure since I do not understand much of what you typed.
RayCrew
Marking this as assumed answered is not correct.
RayCrew
Seven months later and still no real response from ESRI makes me sad.
KellyGerrow
Esri Alum
Hi Ray,
Thanks for your feedback. This is definitely something that we are considering for a future release in the software but is not available without the above mentioned workarounds. If this is specific to a search widget, you can set the default zoomn in most configurable apps and with url parameters.
-Kelly
EricPeña
This is exactly what I need to do but it seems url parameters cannot be concatenated.  I've tried query & scale as well as find & scale parameters but neither seem to take the scale setting, they just ignore the scale setting.  See examples below:
query & scale parameter
In addition the Search Widget zoom scale settings are not available for Feature layer searches, only Geocoder searches.
Ke_Xu
by Esri Regular Contributor
Hi All,
Now, for 2D maps, you can limit the scale range that users can zoom to. It has been released on ArcGIS Online in February 2025, will be released on ArcGIS Enterprise 11.5 and ArcGIS Experience Builder Dev Edition 1.17.
The map bar shows the level of detail(LODs) of the basemaps in the connected maps.
Ke
