I am currently attempting to add the necessary licences (as an admin) to be able to use ArcGIS Pro, but while the licence tab is visible, when accessed it merely leads to a blank page. I've tried multiple browsers, but the same issue persists. Any help would be greatly appreciated.
I can't reproduce this, licenses show up normal(using Chrome):
Did you try a different computer? Might be best to contact Esri Support to work through the issue.
I'd suggest getting in touch with tech support or customer service. I would suggest verifying that the licenses have been provisioned to your organization with customer service. They can then get you over to tech support if they can't address the issue.
-Kelly
Did you ever a get a solution for this? I'm just setting up our accounts and coming across the same issue.
I'm also getting the same issue. The 'ArcGIS Pro' and 'Other Products' buttons appear for a fraction of a second and then disappear - leaving the page blank.
I have tried this in a couple of different browsers (IE and Chrome) as well as from outside the corporate firewall and I see the same behaviour each time.
