ArcGIS Online - GeoForm - Multiple addresses?
1512
01-10-2018 07:33 AM
AlexP_
Hello,
I have a GeoForm from ArcGIS Online template. Do we have mulitple addresses to add on geoform at one time to submit? For example, all the information is the same to fill out except mulitple different addresses at one time to submit? To avoid repeat to fill out same information except address.  Please advise! Thank you!
CarmelConnolly
Hi Alex,
I don't think it's possible to add multiple points in a single Geoform entry - it's worth voting on this idea: https://community.esri.com/ideas/11779
Have you considered using Survey123? It allows you to create a web form and to define default values. You would have to complete multiple forms but the answers would be preselected for you.
Survey123 also has a mobile app that allows you to Favourite answers: https://community.esri.com/groups/survey123/blog/2015/07/29/how-to-pre-populate-answers-in-survey123
Alternatively, another app called Collector for ArcGIS allows you to copy existing features (their attributes), and plot them: Add a feature—Collector for ArcGIS | ArcGIS
Carmel
CarmelConnolly
Hi Alex,
Carmel
AlexP_
Thank you Carmel for your reply.
Does geoform has edit or undo? Once to submit entry but what if need to edit or undo? Please advise. Thanks again.
CarmelConnolly
Hi Alex,
Geoform does not have an edit or undo option.
If a change needs to be made to the data (edit/delete etc.), the change can be made in the web map or through another application that has editing functionality like Web AppBuilder
Carmel
AlexP_
Hello Carmel,
I learned that collector app doesn't have copy attribute exising feature and then input different location (type search specify address instead locate me here). Am I doing something wrong? Is there any similar app for this? Please advise. Thank you!
CarmelConnolly
Hi Alex,
Ahhhh I'm not aware of a piece of software that fits exactly that need.
Do you know the addresses ahead of time? Could they be plotted on the map and used as a reference for the new point?
Another way could be to use Collector or Geoform etc to collect the points at the addresses and then use this tool in Web AppBuilder to batch populate fields with the same information.
Carmel
