Should be a fairly obvious answer here, I created a Custom Role named GIS_Tech based on the Publisher role but with an added privilege of Update & Invite Members . When the role was assigned to a user and he logged in there does not seem to be a way to exercise this privilege.
As the Administrator I see the various choices under "My Organization", one of which is "Invite Members", the GIS_Tech role has none of these options.
Obviously I am missing something here.
Keith
Solved! Go to Solution.
Under Administrative Privileges, Members, you also need to check View All. If you select Invite, View All gets checked automatically. Perhaps it got unchecked...
Mike
Mike
Exactly the right answer, appreciate the rapid reply.
