ArcGIS online attribute expression - if - then question
1166
03-25-2018 07:14 AM
TerriRogers
New Contributor II
In ArcGIS Online, I want to "show more details" in the popup only if a certain criteria is met.  For example I'm working on fire hydrants.  If a hydrant needs to be repaired I want to see a "more info " detailed popup, so we know if we have a broken stem, or needs painted.  I think i would need to add this to the attribute expression in popups, but not sure.
If it doesn't need to be repaired then i only need to see only a few details, like address and manufacturer.
Any help is appreciated.
XanderBakker
Esri Esteemed Contributor
TerriRogers
New Contributor II
Thank you so much I will look at it.
Terri
TerriRogers
New Contributor II
Yes, thank you – someone also mentioned this site.
Terri
