ArcGIS Online 7.4: How to publish an enterprise geodatabase on ArcGIS Online with an option not to copy the data,
691
03-13-2020 05:58 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out if there is a way to publish enterprise geodatabase on ArcGIS Online with an option not to copy the data. This way, as the published data is edited on the web or mobile, the updates are reflected in the real time to the enterprise geodatabase.
Saleh Ahmed
Rawan Saleh
Jamal Numan
NickLawalin
Hi Jamal,
As far as I know this is not possible when publishing to ArcGIS Online.  Publishing to ArcGIS Online is always does a Copy Data.  To do what you're saying you would need to publish to your own ArcGIS Server and then "Register" the service in your ArcGIS Online.  That would keep the link to your live Enterprise Geodatabase in ArcGIS Online.
ArcGIS Server web services—ArcGIS Online Help | Documentation
JamalNUMAN
Thank you Nick.
I was thinking that this could be accomplished without the need to have the ArcGIS Server deployed.
Jamal Numan
