ArcGIS Dashboard Serial Chart - Data Question
1272
06-08-2021 02:04 PM
GISPro1
I am creating a chart in ArcGIS Dashboard from a table.  Each record in the table contains ParcelID and OutreachType.  Each parcel has multiple entries.  I need to create a serial chart that shows the number of parcels by the number of outreach attempts.  For example:
ParcelID     OutreachType
12345         Email
12345         Phone
12345         Visit
54321         Visit
54321         Email
So the output that I need in the serial chart would be:
Parcels by Attempt Number
1 = 0
2 = 1
3 = 1
Seems very straightforward, right?  It's got this non-developer stumped.  Thank you for your help.
GISPro1
Actually, I figured it out with a little Arcade.
First I set up the following expression to return a FeatureSet:
return GroupBy(fs,['ParcelNum'],
[{name: 'total_attempts',expression: 'OutreachAt', statistic: 'COUNT'}]);
Then set the Category field to 'total_attempts' with a simple count by 'Row_ID'
Worked like a charm!
DavidPike
MVP Frequent Contributor
Can you explain more what parcels by attempt number is supposed to be? I can't work it out.
GISPro1
Sorry about that.  From the example... ParcelID 12345 has 3 outreach attempts (email, phone, and visit), Parcel 54321 has 2 outreach attempts (visit and email).  So with this limited dataset, there is 1 parcel with 2 attempts and 1 with 3 attempts.  As this table grows, I want to report on the number of parcels that have 1 attempt, 2 attempts, 3 attempts, 4 attempts, etc.  Does that make better sense?
DavidPike
Thanks for clarifying, I don't actually think it's straightforward as I'm leaning towards a data expression being required to do the heavy lifting.  Or maybe/hopefully I'm missing something simple.
GISPro1
