Arcgis 10.4 or higher not recognize .prj files in shapefile
1131
06-02-2019 07:51 AM
JoelsonPassos
Hello guys.
I have a problem with Arcmap 10.4 or higher.
I have some shapefiles with the .prj file, but Arcgis 10.4 does not recognize them.
When I import the shapefile the message Unknown Spatial Reference appears.
In ArcGis 10.3 and below the shapefile coordinate system (.prj) is recognized.
To recognize the coordinate system, I have to use the "Define Projection" tool.
In the .prj file that is in the shapefiles it is like: "GEOGCS["SIRGAS 2000",DATUM["D_SIRGAS_2000",SPHEROID["GRS_1980",6378137,298,257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0,017453292519943295]]"
When I use the Define Projection Tool it looks like this: "GEOGCS["GCS_SIRGAS_2000",DATUM["D_SIRGAS_2000",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433],AUTHORITY["EPSG",4674]]"
When copying the .prj file to a folder "C:\Users\User\AppData\Roaming\ESRI\Desktop10.4\ArcMap\Coordinate Systems" the message appear "Failed to get a coordinate system from "C:\Users\User\AppData\Roaming\ESRI\Desktop10.4\ArcMap\Coordinate Systems\Sirgas 2000.prj; the file may be corrupt" appear.
How do I automatically recognize the coordinate system for ArcGis?
NeilAyres
The clue seems to be the datum reference in the AIR.prj.
ArcGIS does not recognise this as a proper datum reference :
