In an AGOL webmap, I have an Attribute Expression (that I sourced from here😞
// get the states layer
var portal = Portal('https://arcgis.com')
var states = FeatureSetByPortalItem(
portal,
'a454cf97c4264cd2b77f27175e01d3ba',
3,
['ABBRV']
// intersect feature with States
var xs = Intersects(
$feature,
states
// create array of intersected state names
var c_array = []
for (var c in xs){
Push(c_array, c['ABBRV'])
// remove duplicates
var unique_states = Distinct(c_array)
// concatenate array, return string
return Concatenate(unique_states, ', ')That works as expected: user clicks on a line, pop-up returns a list of state(s) that the selected line intersects.
Here's the problem: the line is multiple parts (features? Sections?). CHunked up by numerous attributes (state, county, district, etc....). So if the user clicks on a line segment, they get the state(s) that the segment intersects.
But what I want is:
Every single state the ENTIRE line intersects, based on the name of the line. So if the NAME attribute of the line they click on is "BIGFOOT", some sort of magical arcade thing that FIRST selects every single line segment (which could be dozens) with NAME = "BIGFOOT", then do the intersect and return every state intersected by every line segment where NAME = "BIGFOOT".
I'd vote for "features". "parts" makes it sound like you're working with multipart geometries, and the expression should work as expected there.
To do what you want, you need to modify Josh's expression a bit:
portal,
3,
['ABBRV']
// get the lines layer
var lines = FeatureSetByPortalItem(
portal,
'id',
0,
['NAME']
// get all lines that have the same NAME as the current $feature
var name = $feature.NAME
var filtered_lines = Filter(lines, "NAME = @name")
var c_array = []
// iterate over the filtered lines
for(var f in filtered_lines) {
// intersect that line with the states
var xs = Intersects(f, states)
// get the intersected states' names
for (var c in xs){
portal,
3,
['ABBRV']
portal,
'id',
0,
['NAME']
var c_array = []
for (var c in xs){
That worked perfectly!
Sadly, performance is....lacking.
Eg. I have a line with 36 features that passed thru 3 states. The result (pop up) takes 2-3 minutes to execute, on a very fast computer and very fast internet. Is this just a hard limitation of Arcade that can't be worked around?
I guess (!) this is another case of this phenomenon, where accessing a featureset for the first time takes a lot of time. If that is the case, then the number of lines and states for a particular trail doesn't really matter, only the total number of lines and states.
But 2-3 minutes is really excessive. Sadly, I don't really have an idea for making it faster right now. Maybe consider precomputing those numbers, as they seem to be static.
