Arcade - Return INFO for value from list
761
04-03-2025 05:39 AM
Luciečervená
I'm kinda noob in arcade. I'm trying to achieve an interactive map where a person clicks on a parcel and pop-up shown information about whether the land is affected by any restrictions or what land-use it is in. Unfortunately, a parcel can be in two or more land-uses/study area etc. and I don't know how to display information for more than one variable.
Showcase is for study area. I'm using arcgis online map viewer pop-up arcade ("newly" allowing use html).
  • If parcel is in 0 studia area, pop-up shows nothing (correct),
  • if <0 or =100 area of parcel is in 1 study, pop-up shows how much % of area of parcel is in study area + info for the study + common info for all studies (correct)
  • if cnt > 1 it show header (hlavicka) of table + common info for all studies but nothing between
I would like to achieve of format:
■ X% of parcel in STUDY AREA:
US.01
US.02
■ Insert study US.01 info
■ Insert study US.02 info
■ Common info for all studies
I know its kinda confused in "var DefUS01 = IIF(percentage > 0 && US_info == 'US.01'" because if it's cnt > 1 → US_info is in format:
US.0X
US.0X
so it's not gonna find any match. If i ty to use IIF(percentage > 0 && Find('US.01', US_info) it's failing too. I need something to to say "if % of area is bigger than 0 and you find value US.01 in US_info return text.
It's even possible to achieve something like this without changing attribute table for easier value calling?
var prunik = Intersects((FeatureSetByName($map, "Územní studie")), $feature);
var cnt = Count(prunik);
var intersectArea = 0;
/////////Calling study ID + info
var US_info = ""
for (var US in prunik) {
  if (US_info == "") { US_info = US.Id; }
  else { US_info += "<br>" + US.Id; } }
if (cnt > 0) {
    // we have overlap
    for (var prunikArea in prunik) {
        // intersect with polygon, and add area to the total
        intersectArea += Area(Intersection($feature, prunikArea), "vymeraparcely");
    // calculate the percentage of overlap
    var zoneArea = Area($feature, "vymeraparcely");
    var percentage = Round(intersectArea * 100.0 / zoneArea, 1);
    // format the resulting text for > 0 < 100
    var result = "<tr><td>■ " + percentage + "% of parcel in <strong>STUDY AREA - " + US_info + "</strong>. " + "</td></tr>";
    //format conditions for final text
    var hlavicka = IIF(percentage > 0, "<table><tr><th>Územní studie</th>", "")
    var RegIN100 = IIf(percentage == 100, "<tr><td>■  Parcel in <strong>STUDY AREA  - " + US_info + ". " + "</strong></td></tr>", "")
    var RegIN = IIF(percentage > 0 && percentage < 100, result, "")
    var konec = IIF(percentage > 0, "</table>", "")
    var DefUS01 = IIF(percentage > 0 && US_info == 'US.01', "<tr><td><br>■ <u>Insert study US.01 info</u></tr></td>", "" )
    var DefUS02 = IIF(percentage > 0 && US_info == 'US.02', "<tr><td><br>■ <u>Insert study US.02 info</u></tr></td>", "" )
    var DefUS04 = IIF(percentage > 0 && US_info == 'US.04', "<tr><td><br>■ <u>Insert study US.04 info</u></tr></td>", "" )
    var DefUS05 = IIF(percentage > 0 && US_info == 'US.05', "<tr><td><br>■ <u>Insert study US.05 info</u></tr></td>", "" )
    var DefUS06 = IIF(percentage > 0 && US_info == 'US.06', "<tr><td><br>■ <u>Insert study US.06 info</u></tr></td>", "" )
    var DefUS07 = IIF(percentage > 0 && US_info == 'US.07', "<tr><td><br>■ <u>Insert study US.07 info</u></tr></td>", "" )
    var OBECust = IIF(percentage > 0, "<tr><td><br>■ Common info for all studies</tr></td>", "")
///////// Final Text
var finalText = hlavicka + RegIN + RegIN100 + DefUS01 + DefUS02 + DefUS04 + DefUS05 + DefUS06 + DefUS07 + OBECust + konec
return {
  type : 'text',
  text : finalText //this property supports html tags
If intersect with 2 study areas - not workingIf intersect with 2 study areas - not workingIf intersect with part of the study area - workingIf intersect with part of the study area - workingIf intersect with 1 study area (100% intersect) - workingIf intersect with 1 study area (100% intersect) - working
Luciečervená
With help of support and chatGPT i manage to make it work as requested:
Now it's returning list of studies that intersect selected feature, description of all studies from list and common text for all studie. And nothing if there is no intersection.
// SETTINGS
var stArLyrName = "Územní studie"; // layer name
var stArIdAttr = "Id";             // field with ID
// FETCH INTERSECTING FEATURES
var studiesFS = FeatureSetByName($map, stArLyrName);
var intersectingStudies = Intersects(studiesFS, $feature);
// Prepare storage
var studyList = "";
var studyDescriptions = "<table style='width:100%; margin-top:10px;'>";
var hasValidStudy = false;
// Parcel area
var parcelArea = $feature["st_area(shape)"];
// LOOP through intersections
for (var study in intersectingStudies) {
    var id = study[stArIdAttr];
    var interGeom = Intersection($feature, study);
    var intersectArea = Area(interGeom, "square-meters");
    var percent = IIF(parcelArea > 0, (intersectArea / parcelArea) * 100, 0);
    var percentRounded = Round(percent, 2);
    // Only if more than 0.05%
    if (percent > 0.05) {
        hasValidStudy = true;
        // Add to list
        studyList += "■ " + id + " (" + Text(percentRounded, "#.##") + "%)<br>";
        // Add description
        if (id == "US.01") {
            studyDescriptions += "<tr><td style='padding-top:8px;'><br>► <u>Územní studie pro plochu US.01 prověří a navrhne:</u><br>" +
            "<b>a)</b> uspořádání a způsob zastavění území, zejména urbanistickou strukturu, při zohlednění ochranného pásma VN vedení, pásma 50m od hranice lesa a těsné blízkosti lokality soustavy Natura 2000 (EVL), v souladu s podmínkami uvedenými v kap. F ÚP,<br>" +
            "<b>b)</b> postup výstavby s ohledem na stanovenou etapizaci a s podmínkou přednostního využívání území v návaznosti na stávající zástavbu,<br>" +
            "<b>c)</b> dopravní napojení plochy na ul. Zátiší, s napojením západní části plochy (Z.09A, Z.09B a P.02) nejméně ve dvou místech se zokruhováním obslužné komunikace a způsob vnitřní dopravní obsluhy plochy,<br>" +
            "<b>d)</b> umístění a charakter veřejných prostranství v rámci ploch bydlení Z.09A, Z.09B, Z.10 a P.02,<br>" +
            "<b>e)</b> řešení napojení ploch na technickou infrastrukturu a vnitřní rozvody sítí technické infrastruktury v plochách,<br>" +
            "<b>f)</b> ekologicky příznivý způsob likvidace povrchových (dešťových) vod na základě hydrologického posouzení lokality.<br></td></tr>";
        else if (id == "US.02") {
            studyDescriptions += "<tr><td style='padding-top:8px;'><br>► <u>Územní studie pro plochu US.02 prověří a navrhne:</u><br>" +
            "<b>a)</b> uspořádání a způsob zastavění území, zejména urbanistickou strukturu, při zohlednění ochranného pásma VN vedení, OP lesa, zařízení pro odvodňování území, evidovaného výhradního ložiska nerostných surovin, dobývacího prostoru a poddolovaného území, v souladu s podmínkami uvedenými v kap. F ÚP,<br>" +
            "<b>b)</b> postup výstavby s podmínkou přednostního využívání území v návaznosti na stávající zástavbu,<br>" +
            "<b>c)</b> ochranu objektů bydlení a dalších aktivit citlivých z hlediska hlukové zátěže před hlukem z provozu na ulici Podkrušnohorská,<br>" +
            "<b>d)</b> dopravní napojení plochy na ul. Podkrušnohorská (v severním i jižním směru), zajištění severojižního propojení obou větví ul. Podkrušnohorská a způsob vnitřní dopravní obsluhy plochy,<br>" +
            "<b>e)</b> citlivé řešení vazby nové zástavby na stávající zástavby uvnitř plochy bydlení Z.14 a napojení na plochu veřejné zeleně Z.36 a plochu krajinné zeleně,<br>" +
            "<b>f)</b> umístění a charakter veřejných prostranství v rámci plochy bydlení Z.14,<br>" +
            "<b>g)</b> řešení napojení ploch na technickou infrastrukturu a vnitřní rozvody sítí technické infrastruktury v plochách,<br>" +
            "<b>h)</b> řešení zástavby s ohledem na stávající hlavní odvodňovací zařízení v ploše Z.14, okolo kterého bude zachován nezastavěný manipulační pruh v šířce 4m od osy zařízení na obě strany, při řešení odvodnění plochy bude vyloučeno vypouštění odpadních i dešťových vod do odvodňovacího zařízení,<br>" +
            "<b>i)</b> ekologicky příznivý způsob likvidace povrchových (dešťových) vod na základě hydrologického posouzení lokality.<br></td></tr>";
        else if (id == "US.04") {
            studyDescriptions += "<tr><td style='padding-top:8px;'><br>► <u>Územní studie pro plochu US.04 prověří a navrhne:</u><br>" +
            "<b>a)</b> uspořádání a způsob zastavění území, zejména urbanistickou strukturu, v souladu s podmínkami uvedenými v kap. F ÚP,<br>" +
            "<b>c)</b> harmonickou vazbu na okolní zástavbu podél ul. Žižkova při respektování uliční hrany zástavby,<br>" +
            "<b>d)</b> ochranu objektů bydlení a dalších aktivit citlivých z hlediska hlukové zátěže před hlukem z provozu na ulici Žižkova,<br>" +
            "<b>e)</b> dopravní napojení a způsob vnitřní dopravní obsluhy plochy, se zajištěním pěší prostupnosti mezi ul. Žižkova a Pietním parkem, při respektování koncepčních prvků stanovených v ÚP,<br>" +
            "<b>f)</b> umístění a charakter veřejných prostranství v rámci ploch,<br>" +
            "<b>h)</b> ekologicky příznivý způsob likvidace povrchových (dešťových) vod na základě hydrologického posouzení lokality.<br></td></tr>";
        else if (id == "US.05") {
            studyDescriptions += "<tr><td style='padding-top:8px;'><br>► <u>Územní studie pro plochu US.05 prověří a navrhne:</u><br>" +
            "<b>a)</b> uspořádání a způsob zastavění území, zejména urbanistickou strukturu, při zohlednění poddolovaného území a území s archeologickými nálezy, v souladu s podmínkami uvedenými v kap. F ÚP,<br>" +
            "<b>e)</b> dopravní napojení a způsob vnitřní dopravní obsluhy plochy, se zajištěním pěší prostupnosti mezi ul. Žižkova a sportovním areálem, při respektování koncepčních prvků stanovených v ÚP,<br>" +
        else if (id == "US.06") {
            studyDescriptions += "<tr><td style='padding-top:8px;'><br>► <u>Územní studie pro plochu US.06 prověří a navrhne:</u><br>" +
            "<b>a)</b> uspořádání a způsob zastavění území, zejména urbanistickou strukturu, při zohlednění území s archeologickými nálezy, poddolovaného území, OP vedení VN, území zvláštní povodně pod vodním dílem, v souladu s podmínkami uvedenými v kap. F ÚP,<br>" +
            "<b>b)</b> koordinaci se záměrem cyklostezky v koridoru CNU.05,<br>" +
            "<b>c)</b> postup výstavby s podmínkou přednostního využívání území v návaznosti na stávající zástavbu,<br>" +
            "<b>d)</b> harmonickou vazbu na okolní zástavbu podél ul. Sklářská a Jandečkova a na rozvojové území v ploše P.05,<br>" +
            "<b>e)</b> dopravní napojení se zajištěním dopravního napojení nejméně ve třech místech, do ul. Podkrušnohořská, ul. Loupnická a prodloužené ul. Jandečkova, případně též do ul. Sklářská, a způsob vnitřní dopravní obsluhy plochy se zokruhováním obslužné komunikace,<br>" +
            "<b>f)</b> zajištění pěší prostupnosti mezi plochami veřejné zeleně západně a plochou P.05 východně, při respektování koncepčních prvků stanovených v ÚP,<br>" +
            "<b>g)</b> umístění a charakter veřejných prostranství v rámci ploch,<br>" +
            "<b>h)</b> řešení napojení ploch na technickou infrastrukturu a vnitřní rozvody sítí technické infrastruktury v plochách,<br>" +
        else if (id == "US.07") {
            studyDescriptions += "<tr><td style='padding-top:8px;'><br>► <u>Územní studie pro plochu US.07 prověří a navrhne:</u><br>" +
            "<b>a)</b> uspořádání dopravního prostoru a vazbu na navazující zástavbu, v souladu s podmínkami uvedenými v kap. F ÚP,<br>" +
            "<b>b)</b> úpravu stávající křižovatky k zajištění maximální bezpečnosti dopravy s preferencí tramvajových vozidel MHD dynamickým způsobem řízení,<br>" +
            "<b>c)</b> bezkolizní a bezpečné vedení tramvajové trati včetně nové polohy nástupišť,<br>" +
            "<b>d)</b> postup výstavby s podmínkou minimalizace dopadu realizace stavby na plynulost dopravy na křižovatce,<br>" +
            "<b>e)</b> citlivou vazbu na okolní zástavbu podél ul. Žižkova, S.K. Neumanna a Vrchlického při respektování uliční hrany zástavby,<br>" +
            "<b>f)</b> koordinaci s řešením regulačního plánu pro navazující území Litvínov – Osada v ploše RP.01,<br>" +
            "<b>g)</b> zachování pěší prostupnosti po obou stranách ul. Žižkova, S.K. Neumanna a Vrchlického a zajištění dostatečného množství pěších přechodů, včetně přechodů na tramvajové zastávky,<br>" +
            "<b>h)</b> řešení napojení plochy na nezbytnou technickou infrastrukturu,<br>" +
// Close table
studyDescriptions += "</table>";
// FINAL TEXT
var finalText = "";
if (hasValidStudy) {
    finalText = "<div style='text-align:center; font-size:16px; font-weight:bold; margin-bottom:8px;'>Územní studie</div>" +
    "<div style='margin-bottom:10px;'>► Pozemek se nachází v území, ve kterém je rozhodování o změnách podmíněno zpracováním územní studie:</div>" +
    "<div style='margin-bottom:10px;'>" + studyList + "</div>" +
    studyDescriptions +
    "<div style='margin-top:10px;'>► Územní studie budou pořízeny a schváleny pořizovatelem včetně vložení dat do evidence územně plánovací činnosti do 4 let od nabytí účinnosti opatření obecné povahy, jímž se vydává Územní plán Litvínov.</div>";
// RETURN
return {
    type: 'text',
    text: finalText
JohnEvans6
I meant to get to this today and ran out of time. I didn't get a chance to fully noodle through your script, but below is something where if you click a fire perimeter boundary, it will tell you which Census Tract(s) are under as well as the percent for each (one-to-many). I've tried to use ESRI data so you can make your own map. The expression goes on the current perimeters layer
// Boundaries : https://services.arcgis.com/P3ePLMYs2RVChkJx/arcgis/rest/services/USA_Census_Tracts/FeatureServer/0
// Fires : https://services9.arcgis.com/RHVPKKiFTONKtxq3/ArcGIS/rest/services/USA_Wildfires_v1/FeatureServer/1
var boundaries = FeatureSetByName($map, "USA Census Tract Boundaries",['*'], true)
var intersections = Intersects(Geometry($feature), boundaries)
var output_text = ''
for(var f in intersections) {
	var txt = ''
	var percent = ''
	var intersection_size = ''
	// What is the size of the area that intersects the tract and the fire perimeter
	intersection_size = Area(Intersection($feature, f), "acre")
	// What % of the fire perimeter is inside the tract?
	percent = Text(Round(intersection_size / Area(Geometry(f), "acre") * 100))
	// Create an individual line for each
	txt = Concatenate(['<p>', f['FIPS'],": is ", percent, "% affected by fire.", '</p>'])
	// Output
	output_text = output_text + txt
Console(output_text)
return {
	type : 'text',
	text : output_text
Luciečervená
// SETTINGS
// Prepare storage
var studyList = "";
// Parcel area
        // Add to list
        // Add description
// Close table
// FINAL TEXT
var finalText = "";
    studyDescriptions +
// RETURN
return {
    type: 'text',
    text: finalText
