I have an arcade popup working between a parent and child. I need to incorporate popup text from the child to another child. This is a survey123 form that essentially has three levels.
Are you using FeatureSet for this? I would think you could grab the child, get the child globalid, then query the grandchild on parentglobalid. I personally have my own relationships class where I pass my own keys down the line.
May help to post the code you have so far.
I do it like this. Just add another level. Hope that helps
var sql = "PointID = '" + $feature.PointID + "'";
var tbl = Filter(FeatureSetByName($map,"Points", ['*']), sql);
var val
for (var row in tbl) {
val = row.CollectCoreSubset1
return val
