Arcade now and timestamp not returning as documented
92
a week ago
Morin
New Contributor II
How do I know if a date is locale or UTC, it does not make sense?
Why is there a timesone aware "mark" (+2:00) on what is returned from now()?
Using arcade this is what is being returned.
now() - 2021-05-04T09:02:03+02:00
Timestamp() - 2021-05-04T09:02:03+02:00
I would expect now to just return the locale datetime and nothing else?
I don't recognize any of this from the documentation:
https://developers.arcgis.com/arcade/function-reference/date_functions/#now
Returns the current date and time
e.g. Mon Oct 24 2016 12:09:34 GMT-0700 (PDT)
From documentation https://developers.arcgis.com/arcade/function-reference/date_functions/#timestamp
Returns the current date and time in UTC time
e.g. 29 Mar 2017 08:37:33 pm
XanderBakker
Esri Esteemed Contributor
Hi @Morin ,
What you are seeing is when you write the Now() or Timestamp() to the console, right? If you return the date value you will probably see a date and no indication for the time zone.
When you create a date it will be created in the local time (in your time zone). The +2:00 you are seeing indicates the time zone, which in my case is -5:00 (Colombia). When you create the current time with Now() it will give you the local date time and with Timestamp() it will give you the current UTC date time.
Have a look at a couple of examples below:
Now(): 2021-05-05T09:39:28-05:00
ToUTC(Now()): 2021-05-05T14:39:28-05:00
ToLocal(Now()): 2021-05-05T04:39:28-05:00
ToLocal(ToUTC(Now())): 2021-05-05T09:39:28-05:00
The first, second and fourth lines are correct. The 3rd line does not make sense. I am using ToLocal to convert a UTC date time to my local time zone, but I provide a local time.
Same goes for Timestamp; the first, third and fourth are correct. The second does not make sense since I use a UTC date time and use ToUTC to convert it to UTC. The function assumes that the date time is provided in local time, but it is not the case.
Timestamp(): 2021-05-05T14:39:28-05:00
ToUTC(Timestamp()): 2021-05-05T19:39:28-05:00
ToLocal(Timestamp()): 2021-05-05T09:39:28-05:00
ToUTC(ToLocal(Timestamp())): 2021-05-05T14:39:28-05:00
When working with date time, it is important to know in what time zone there are expressed to be able to handle them correctly.
I do agree that this can be very confusing and prone to errors.
