arcade: cancel new line in Null field
731
07-07-2022 12:18 AM
gal_s_1993
hi,
I want in the popup tab that when I have a field that is NULL it will not open a new line.
I tried to add a feature like in the solutions offered to me and still does not work for me
I add this:
IIF (IsEmpty($feature.Location), "", "block");
and in the HTML this:
<table><tbody>  <tr style="display:{expression/expr0}">    <td style="width:125px; text-align:left; background-color:#ede8e8; padding:5px">Location</td>    <td style="width:225px; text-align:left; background-color:#ede8e8; padding:5px">{Location}</td>  </tr>  <tr style="display:{expression/expr1}">    <td style="width:125px; text-align:left; background-color:#ede8e8; padding:5px">Region</td>    <td style="width:225px; text-align:left; background-color:#ede8e8; padding:5px">{Region}</td>  </tr>  </tbody> </table>
And yet it does not cancel out the new line for me,
How can I undo the new line in an empty field?
thanks
jcarlson
MVP Alum
Try specifically setting the display value for null attributes to be none.
Iif(IsEmpty($feature.Location), 'none', 'block');
 Also, if you're using the new Map Viewer, there's an Arcade section that can be added to your popup that gives you a lot more control over the style and display of expression-based data.
- Josh Carlson
Kendall County GIS
