Arcade and ArcCollector - Getting X and Y through Popups
646
02-14-2019 05:58 AM
TomRuff
I'm trying to pass the X and Y co-ordinates of a point location to Survey123 through collector.
When I test it via the online webmap it works perfectly however when using Collector (the beta aurora version) it passes 0 to the field in Survey123.
Is arcade currently not supported in the Beta version of Aurora? or is there some other problem?
Tom.
RussRoberts
Esri Notable Contributor
I would post this question under https://community.esri.com/community/gis/applications/collector-for-arcgis  Also note are you using iOS or Android and build numbers.
TomRuff
Thanks I will post it there as well. I'm using the latest build of Arc Collector (Beta) for Android.
