Alternative to Explorer Online Queries
2156
10
01-07-2014 07:02 AM
MarkMcComb
We were using ARCGIS online with queries built in ARCExplorer:
Now we all know this is no longer available: and this makes ARCGIS online a useless tool .
What good is a paper map on a computer.
  This has left us scrambling trying to come up  with an available app  will allow  Querying my layers. And will work  inside
and organizational account ?
  Don't point to ARCGIS Explorer on line: that does not work and will not after March.
Is ESRI planning on fixing these issues and if so when: hopfully before My account expires on ArcGIS online because there is no reason  I can see to renew something that is trash
MarkMcComb
ESRI  (Andrew Stauffer) took the time and  showed my how to use the address locator function within ARC Catalog to build a Composite
address layer, and to post it in services layer to allow for querying of  my data within an organizational account. This allows the bypassing of ARCEXPLORER  for building queries for use within ARCGIS on-line.
by Anonymous User
Not applicable
We had 5 feature classes that we wanted to be able to search for individual features on so we did the following:
1. Create a Locator in Desktop for each Feature Class
  a. Use the General Single Field Locator style
  b. Set data as Primary
  c. Define field to search on as 'KeyField'
2. Create a new Composite Locator
a. Add the Locators you created in Step 1.
3. Publish the Composite Locator to ArcGIS for Server
4. Log into ArcGIS Online
a. Edit Settings
b. Utility Services
c. Add Geocoding Service and save
5. Test searches in Browser based and Mobile applications
a. Adjust locator sensitivity as needed (Min Match Score and Spelling)
Cheers,
Andrew
BrianVillers
Is it possible to publish the Geocode Service to your organizations Hosted Services rather than to ArcGIS for server.
Brian
by Anonymous User
Not applicable
Hi Brian,
Unfortunately you cannot publish locators to ArcGIS Online at this time. If you do not currently have ArcGIS for Server, you can still create the queries using Explorer Online directly at http://www.arcgis.com/explorer when creating a new or opening an older existing map. (New maps created or saved in the Map Viewer will not open in Explorer.)
Thank you,
Andrew
BrianFlood
hi andrew
that's a cool workaround for custom searches in the AGOL apps until something better comes out, thanks.
we're already experimenting with some lightweight services for AGOL Org accounts using Arc2Earth, so I decided to build your workaround into a full service without the need for an ArcGIS Server. You point the service back at any Feature Service you have hosted in your AGOL account, set a few options and voila, simple search on multiple feature services.
some more info will end up here: http://bit.ly/1cwXu84
cheers
brian
MaryEllen_Perko
Hi.  I like the idea of using custom locators in AGOL to simulate queries.  Unfortunately, I'm getting "The geocode service URL you have entered is invalid or inaccessible" when I try to add mine to agol.  I know the service is accessible and the URL works in a browser and works in ArcMap.
But, I did not create and publish a composite locator.  Is that what's missing for mine to work?
Thanks.
by Anonymous User
Not applicable
Hi Mary,
If your locator is public, do you mind posting or sending me a message with the URL to your locator?
Does your locator support single line input?
Andrew
by Anonymous User
Not applicable
hi andrew
Hi Brian,
We've been working to implement something similar that will be in the core product. Cool solution you created!
Andrew
BrianFlood
hi andrew
thanks, and yes, I'd be very surprised if you weren't building those features into the core. It's a stopgap for now until they're available natively in AGOL but also (at least in the case of Basemaps) as a way for older ESRI apps to use the tile layers (re ArcMap 9.3, 10 etc). Going forward, this infrastructure is more of a way for us to integrate external services into AGOL. it's just that in the short term, it could also be helpful for simple stuff in AGOL (like search)
cheers
brian
