AGS Secured feature service added to agol - get error: Services Directory has been disabled. 403
650
01-20-2021 10:52 AM
OfraAi
I have ags secured feature services, that has been added to agol as a feature service item, with the credentials stored.
This has worked for a long time.
Today we've change the ags server, but the url and credentials are the same.
All of the services works fine, except one. When I click on the layer from the web map overview page, I get an error:
ArcGIS Portal Directory
Error
Error: 403
The item exists, I can see the data in the data tab.
In the overview page, I also have a comment:
[Deleted User] commented 3 years ago
Any idea what happened and what can I do to fix it.
Ofra A
OfraAi
I've solved it myself, so just for the record:
I've check the web map JSON using Ago-assistant, and found that one line was missing, with "itemid".
I've added it and all works fine.
I don't know why it happened.
Ofra A
