I am downloading geojson from a government agency that uses a hosted AGOL instance. The geojson does not appear to come back in the expected format for any polygons with holes (as shown in https://tools.ietf.org/html/rfc7946#appendix-A )
Coordinates of a Polygon are an array of linear ring (see Section 3.1.6) coordinate arrays. The first element in the array represents the exterior ring. ...
Instead, the holes are returned as additional rings with reverse winding order. Is this the expected geojson format to be returned? Is it a configuration on their server (or hosted service) to specify how holes are represented?
Here is an example using the AGOL viewer (notice the holes)
Here is a link to get the geojson returned
Showing that geojson in QGIS, the holes are seen as "filled in". Same happens with FME.
Any suggestions?
Kirk
One other addon to this, the geojson is often very slow with large payload. Is there any documentation regarding how to parse or deserialize if using pbf as the requested output from the service?
