Add Space Between Combined Fields in Field Calculator
12610
34
05-07-2018 07:30 AM
JRAdams
New Contributor III
In the ArcGIS Online field calculator I am trying to combine a few other fields into one (address field) and cannot figure out how to put a space between the fields. I am sure it is something simple, but I am unable to find the answer elsewhere. Please help! I've tried everything I can think of.
Thank you!!! AGOL Admin fieldcalculator #arcgisonline
DougBrowning
MVP Esteemed Contributor
How can I do leading spaces?  It keeps striping them out when using Arcade in a Pop up.
This
return "\n" + "      Line Number Issue! Found: " + txt
Does this - notice no spaces - I want to indent it.
Ideas?
Thanks
DanPatterson_Retired
\a  is the bell, so try it with your speakers off, \n and \t are considered whitespace.  So it python-esque principles are followed, you can always find something that doesn't print, but isn't considered whitespace
a = "\n\t\a     Line Number Issue! Found: "
print(a.strip())
DougBrowning
I tried \n\t\t\t\t\t\t\a and got this
a--!!! Line Number Issue! Found: 1-3
No space or bell.
throw an r in front of the string r" it is now raw encoded"
if it is python that it is using, it isn't python 3
DougBrowning
Arcade says Invalid string when I try that.  This is an Arcade popup not python.
JimmyKroon
Occasional Contributor II
Any html in the string will be interpreted, when the popup is displayed in a browser. So you can use html non-breaking space characters -      - which will be displayed as spaces in the popup. Or a little fancier, you can also use in-line css styling to left-pad the line.
Outputing this as a string should work.
<p style="padding-left:10px;">This is your error!</p>
Jimmy
JimmyKroon
Of course, I above it was interpreted as a space!
That'd be   & n b s p ;         - remove the spaces in the middle.
DougBrowning
I do understand this post.
KellyGerrow
Esri Frequent Contributor
Hey Joe,
If using the calculate option in ArcGIS Online, you need to apply a specific filter in order to only calculate specific fields. Can you log an idea about calculating fields based on table selection on ArcGIS Ideas‌. I think this would be helpful to others also:
Work with fields—ArcGIS Online Help | ArcGIS
-Kelly
JoeBorgione
Vote early and vote often!  https://community.esri.com/ideas/14979
Kelly Gerrow
That should just about do it....
