Add maps and layers onto ArcGIS Online from Desktop 9.3
1120
03-30-2014 08:16 PM
LosMorales1
I'm trying to push map and layer data onto ArcGis Online from ArcMap 9.3 but can't seem to figure it out.  I see instructions online but its using version 10 that has the package tool.  The only thing I see in ArcMap 9.3 is to add data from ArcGIS Online.  However I need to do the opposite.  Is there a way to push data from ArcMap 9.3 onto ArcGIS Online?
TimClark1
Can you use the Arc GIS online file loader instead?  It's under My Content->Add Item.  I think there are file size limitations which may be what you're running into.  I don't think you can sign in from 9.3.
MikeMinami
Esri Notable Contributor
Version 9.3 doesn't support ArcGIS Online. You need version 10 or greater, as I recall.
Mike
