Add blue background to a Popup heading via Arcade Element
749
6
08-30-2023 01:34 PM
Ed_
by MVP Regular Contributor
Based on the code below how can I add a blue background with white text for the headings similar to the one shown in the screenshot below?
Code:
// Create a variable that is the FeatureSet of intersecting feature attributes
var Address = FeatureSetByName($map, "ADDRESS")
var intersectLayer = Intersects(Address, $feature)
// This variable will be used multiple times in the code
var popup = '<h3>Property Summary</h3>';
for (var f in intersectLayer){
 popup += `<b>Address:</b> ${f.FullAddress} <br><br>
// Now bring in the attributes from the next intersected layer
// Next heading
popup += <h3>Next Heading</h3>;
return {
  type : 'text',
  text : popup
Desired output:
Question | Analyze | Visualize
KenBuja
Use the background-color style in the font tag. However, that will be only as long as the text string itself.
var popup = '<h3><font style="background-color:lightblue" color="white">&nbsp&nbspProperty Summary&nbsp&nbsp</font></h3>';
KenBuja
Ed_
Thank you so much Ken, can you please explain what does &nbsp do?
Ed_
I got it so &nbsp is to add an extra white space.
Also is it possible to add a hex code instead of typing out the color name?
like will the code snippet inserted below work?
var popup = '<h3><font style="background-color:#ADD8E6" color="#FFFFFF">&nbsp&nbspProperty Summary&nbsp&nbsp</font></h3>';
Ed_
Yup I just checked it does indeed support HEX codes.
Thank you so much @KenBuja  🙂
PS you can also see that the parcel attributes are now present in the popup.
ArmstKP
Example:
Code:
<div style="background-color:{expression/expr0};color:#FFFFFF;padding:7px;text-align:center;">
    <span style="font-size:medium;">{expression/expr1}</span>
</div>
<figure class="table" style="width:100%;">
    <table style="border-collapse:collapse;font-family:arial, sans-serif;text-align:left;">
        <tbody>
            <tr style="background-color:#eee;">
                <td style="border:1px solid #ddd;padding:8px;">
                    Pool Type
                </td>
                    {Pool_Type}
                </td>
            </tr>
            <tr>
                    Explanation for Closure
                </td>
                    {public_explanation}
                </td>
            </tr>
                    Last Update
                </td>
                    {LastDateInspected}
                </td>
            </tr>
        </tbody>
    </table>
</figure>
Ed_
Awesome 😎 thank you for the detailed response.
