Accessing Non-SDE datasource with an SOE
3414
10-22-2014 06:39 AM
MatthesRieke
Hi all,
is there a way to access and query the underlying datasource of a service that is non in the SDE schema? I have been developing a Java-based SOE which does some querying using the MapServer's DataAccess:
        IMapServer3 ms = (IMapServer3) getMapServerDataAccess();
        String mapName = ms.getDefaultMapName();
        IMapServerDataAccess mapServerDataAccess = sos.getMapServerDataAccess();
        Object dataSource= mapServerDataAccess.getDataSource(mapName, 0);
        FeatureClass fc = new FeatureClass(dataSource);
        workspace = new Workspace(fc.getWorkspace());
This works well if the registered datasource is an SDE database. But when I do this with a non-SDE (using DBO), I receive a different implementation of IWorkspace (in fact an SqlWorkspace object, instead of an IWorkspaceProxy). It throws an AutomationException ("not implemented") for
        workspace.createQueryDef()
calls.
Can I work around this issue? Is there an alternative way to query database data (SqlWorkspace does not seem to have methods for this purpose)?
Thanks and kind regards,
Matthes
