Utilize Multiple Replace Functions
469
07-29-2021 09:39 AM
Status: Open
Robert_Geoffrey_DeWitty
New Contributor II
Please make it possible to call on multiple replace functions in one script. I'm trying to replace multiple values in a spreadsheet column with their respective links(null1 to link 1, null2 to link2) but this is not possible as only the last replace function is called though I'm replacing different values.
2 Comments
RobertBorchert
You should be able to.  At least in Python
If you are using some of the same variables for each portion of the script multiple times you can use
del <variable name> function.
look into that
Also, is it possible to add specific pictures for each pop up on a map? I want each one to display for its respective location but when I add them it just displays multiple in type of mini slide show.
