Suppose you perform an analysis, with the desired settings of limiting the analysis to the current map view, or not. Then, you add something to one of the map note layers for which the analysis was already done. From what I've seen, it is not possible to "refresh" the analysis to include the added point/map note. Instead, a new, unique analysis needs to be created. Is this intentional? Would it be possible to "update" an analysis?
