Survey123 option to remove "Set as Favorite answers" in Survey form
1770
10
01-31-2019 07:44 AM
Status: Open
PaulSweeney3
Occasional Contributor III
Whilst this functionality can be useful when used responsibly it can lead to complacency with users especially when the information collected is very repetitive. An option in settings before publishing the form  to choose if this button is available or not in the survey would be very useful.
10 Comments
deleted-user-qpvAI3Fo0MKR
I like this idea. It would be nice if this parameter could be set in the Settings tab of the XLSForm:
by Anonymous User
The Set as favorite answer can also help if you have multiple pathways within each survey. You can fill one out set as favorite and submit. Then with the new survey finished the remaining pathway your collecting.
tomwang1
Any update on this for new release?
PaulSweeney3
Liam Harrington-Missin genuinely just curious as to why you would not agree with having the option to not include this in a survey form?
GaryElsner1
We need the ability to reuse some answers from a previous survey.  Repeating all of the answers has the risk of creating unwanted duplicates.
Instead of removing this feature, modify it so that it only saves the answers that were filled out when it was saved.  Currently, saved answers are overwritten with all of the answers that had been filled in when that survey is submitted.
Specifically, when you save favorite answers, keep it exactly as it is when saved and only add/change it if you save it again.  Then when you use it for additional surveys, it would only carry forward those answers you intended to repeat.
MatthewAshberry
Currently, the Paste answers from favorites option must be selected for each relevant statement in the survey in order for the questions to be populated completely as when initially saved. This is not at all intuitive and most likely the user will select the paste option once and fill in other fields as desired. Now you have new and old data existing in the sent record. This isn't good and potentially causes a significant amount of erroneous data. Until the behavior is corrected, I would suggest an easy way to disable Favorite answers feature. Ultimately, Favorite answers should not be edited unless it's changed on an initial draft.
Rmesen
We need this!!
DanielMurillo
Hello @PaulSweeney3 you can submit a case to ESRI support so that your account can be added to ENH-000153550 that is now in review and strengten the Enhancement request. The more accounts affected the more visibility this request will have.
RichardCitkowicz
This ability has many unforeseen consequences and is useful in many ways. We would not want the complete removal of the functionally but the ability to choose which fields can not be saved as favorite or the ability to not have the entire form be favorited.
StacyLynnBlanco
This would be very useful. Are you working on it, yet?
