In my workflow, I want to use the same hosted feature layer, but be able to apply different default values for two different web maps. I've noticed the default values are applied at the hosted feature layer rather than at the web map level, which keeps creating issues in this regard when editing data through collector.
Ideally I would like to be able to set the default values similar to the symbology or the filters. Maybe this can be done by adding a default value column to the Pop-up configuration window.
Any advise or update in any implementation in this regard will be highly appreciated.
