They ability to now export formatted reports on Survey123 records is great. Querying desired records and having them displayed on custom branding reports greatly promotes GIS ROI.
It would be beneficial to have this report functionality established for all feature services in ArcGIS Online. The ability to have a widget you can implement in Operations Dashboards would even further benefit the GIS community.
In addition create a solution like this in desktop environment as well like in ArcGIS PRO.
Simply add a Feature Class, Shapefile, etc. in the tool, point the tool to your source report document and select ALL* records or have a SQL Expression, or have the option to use only selected records. Then have it spit out the reports in your desired output location.
I don't see why this amazing new feature is only available for Survey123 hosted feature services, it should be implemented throughout the entire ESRI software suite. Derek Law
We should see Report capability in ArcGIS Pro 2.3: ArcGIS Pro Roadmap - June 2018
So this is In Product Plan for ArcGIS Pro, but since the request is for all Esri products, I'm not able to speak to that right now.
at least its coming for PRO, hopefully attachment related tables will have same functionality like the Survey123 reporting.
This is a great idea... one of the most popular requests we get for web apps is reporting functionality. The export to CSV from the attribute table widget in WebApp Builder isn't a bad option, but it would be great to see something similar to the Survey123 reporting interface across the platform.
This idea is not getting a lot of traction, as is tied to ArcGIS Dashboards specifically. I am going to try moving it to a more generic community to increase its visibility.
