Currently when a polygon is extruded it would appear as if all vertexes are extruded to the same height. This leads to having buildings with sloped roofs due to changing elevation. I would like to see the extrusion methods changed to allow similar methods to ArcGIS Pro where there is a choice to extrude from lowest or highest point.
