ISO 8601 Date Format Support in AGOL, Portal, Collector, Web AppBuilder
1080
04-18-2017 07:17 AM
Status: Open
New Contributor II
International standard date format support (ISO Standard 8601 example: YYYY-MM-DD) is not supported in any of ESRI's AGOL and Portal based solutions. Many organizations mandate the use of this date standard and not having it supported is an impediment to rolling out these solutions.
Having dates in this format gives a predictable and easily sortable date format that is compatible across many systems, especially those that work internationally.
ISO 8601 - Wikipedia
4 Comments
Considering all the recent advancements in technology, the date format support in these applications is very poor. In a web map, on which almost everything depends, there are currently only two possible formats for fields with date and time, US format (m/d/yyyy hh:mm:ss) and international (d/m/yyyy hh:mm:ss) and neither are acceptable when users are international.
The date format used in AGOL itself, most templates and widgets is also US format, which most of the rest of the world does not use.
The ISO date format is designed for these scenarios as it avoids confusion. It should, as a minimum, be one of the format options and ideally, should be the default.
The default date format should also be configured at the organisation or web map level.
At the moment we are constantly having to apologise to customers because the date formats aren't what they require.
In Open data, there is a date created field against each dataset. Would like to see this displayed in Australian Format - i.e. DD/MM/YYYY and not U.S format.
This is also the standard which is compatible with Pandas datetime objects, and in particular the Pandas read_csv function.
How can I vote up?
