I would like to see a hybrid imagery \ streets base map like the one Bing provides but hosted by ESRI. The Imagery base map is good but including street names would make it much more informative.
The Bing Hybrid base map is by far my favorite go to base map. The reason I suggest an ESRI hosted hybrid map is that you cannot use the Bing base maps in Collector offline mode. When in offline mode you also cannot switch between imagery base maps and streets base maps. I do know that I can use the Imagery Hybrid web map but could it be more easily accessible by adding it or something similar to the ArcGIS Online base map picker?
