There is a known issues whereby legends in the print output using the Basic Viewer Application do not display correctly.
(see BUG-000094164 and BUG-000086442). The issue is that the legend displays values as "Override X" when the default symbology is not used (ie. Styling is done in ArcGIS online)
ESRI have no plans to fix the issue as they believe a satisfactory workaround is to republish the data with the desired symbology from ArcMap desktop.
Legends are a fundamental part of every map, and something that users expect to be able to have work correctly. This 'workaround' does not seem to be a satisfactory solution for a number of reasons:
