Hi guys,
Could you please look into enhancing the “date selector” to filter results - when Date Picked is between two time fields (e.g. between Start time field and End time field).
Gee
Another great enhancement would be to have a 'Clear' button to clear the date values. When the dates are filled in, maps and widgets are filtered according to the actions you set up, however, the only way to get back to the original view the dates have to be deleted in one or both fields. So it would more user friendly and efficient to have a 'clear' button to clear the values.
It would also be great to be able to change the formatting of dates much like one can do in Excel using patterns. I have an international user base and some want MM/DD/YYYY while others wants DD/MM/YYYY. I want to be able to provide middle ground by doing MMMM DD YYY but alas, the date format is taken from AGOL settings and that provides no customisation.
