Hello!
It would be nice to copy a popup template from one layer to another in ArcGIS Online and Portal for ArcGIS. I have over 20 layers in a map that all have the same fields but display different points. It would be nice to have a dropdown or something that gives you the choice to take the popup template from another layer (with same fields) and apply it to the next one. It would be nice to also include any media (pictures, charts, etc...) in this transfer.
Chris
Yes. It is important because those of us with server 10.2 < with hundreds of popups know if we publish the popups are deleted. And it snaps to the top each time. This could enable us to back up a lot of popup work, in case something goes wrong, publishing shreds them, etc. AGOL needs this, and to enable ALL popups in one click for a service, or for a group of layers, too.
Even just being able to do this in ArcGIS would be amazing. We're making election results maps, and each one has popups, all with the same template. Currently we have to do each map's popup separately, which takes a long time.
