The ability to open a connection to an ArcGIS Online organization from a stand-alone python script without having to open ArcMap application that is already logged into ArcGIS Online.
arcpy.SignInToPortal_server command does not work in version 10.5.1
ArcGIS API for Python | ArcGIS for Developers is the primary Python API for interacting with ArcGIS Online and ArcGIS Enterprise Portal, and it doesn't require having ArcMap or ArcGIS Pro open to connect.
