I have many layers that overlap, specifically geology layers, and when I click on a point I often receive multiple pop-ups for all layers that this point touches. However, as you click through each of the pop-ups the default title displays one of the attributes (which changes for each layer). I would really like the default to display the layer name, so you know which layer you are seeing. I've just had to manually change a couple of hundred of these in the configuration settings.
