Change data source in AGOL map
1046
10-24-2014 08:06 AM
Status: Open
AngeloMarino
It would be nice to be able to change the source of data in an AGOL map similar to how it is done in ArcGIS.  often I create maps and wnat to change the data source but the only way to do that now is to delete the data in the map and replace it with a new data source.  This makes it necessary to change the popups and anything else related to the data
2 Comments
C_EHoward
check out the AGOL assistant, it may help you
https://ago-assistant.esri.com/
you can change the services used in a web map. you still cannot fix things (like broken popup fields if you change your web map) but it can help if you are replacing a map service with the same data layers
NeillJobe
Check out Admin Tools for ArcGIS Online on the Marketplace also. This free tool gives you this and a lot of other supported tools that you will find useful.
https://marketplace.arcgis.com/listing.html?id=c34019b0623041608df4d06970a7a96a#
