ArcGIS Online Printable Popups(Webmaps and/or Web Apps)
2766
8
12-19-2016 04:12 PM
Status: Open
TylerGakstatter
New Contributor II
Popups within Web maps and web apps are extremely customizable and can be great for creating reports...However there is no way to print or export their contents! This seems like a basic feature that was either over looked or purposefully left out. I don't think it's technically difficult to implement. The only workflow that looks feasible right now requires the use of ArcGIS Server.
The ideal solution(in my mind) would be to add a "print" function at the bottom of the popup that would print the contents with formatting intact)
Popup Print Funtion
8 Comments
BillFox
This should be included with Out-Of-The-Box Web AppBuilder functionality.
That's usually one of the first questions I get when presenting Web AppBuilder applications to our staff.
Çankaya Belediyesi asked about this previously and reply covers in great detail for custom coding.
Printing Popup Contents
by Anonymous User
Hello,
Would you want the print out to have the same look and feel as the pop-up in the web map or web app or would it be preferable to get the information from the pop-up in a printable table?
Would being able to print the attribute table satisfy your needs or would you like the customization done in the pop-up to come through in the print out?
Are you more interested in just printing the information from one pop-up or are you looking for a report or print out of the information from multiple pop-ups?
BillFox
Yes, the report should have the same look and feel as the popup presents.
A nice print table button, an export to CSV button and e-mail button
Example of clicking on a parcel now just takes the x/y and the popup displays 1 of # to view.
It should take the geometry of the parcel (and offer to buffer it +/- number of feet) and overlap it with all the layers in the map.
A typical report could look like this:
Parcel Number:         12345603ST
Flood Control Districts
      AE
      DE
Zoning
      R-1
      R-A
Census Tract   4987
Block Group      54654
Owner   Smith John A
Address    1234 Main Street
City Limits   Redlands
State           CA
Building Permit
      546464
      321312
Assessed Value   656464646
Home Owner Exemption   7000
Senate District   Jones
Election Polling Place   Fire Station 2
Soil Type   Sandy
etc.
berniejconnors
I completely agree - this should be out of the box functionality for WAB and all other AGOL web apps and web maps.  There should be a "Print" button on the bottom edge of the pop-up window.
berniejconnors
Katie,
My suggestions:
  • just print the contents of one pop-up (in case there are several features selected)
  • by default just print the contents of the pop-up in a simple table, perhaps the layer name could be the title for the table:
        PARCELS
  • optionally, allow me to configure the print lay-out for the pop-up data in the web map
Bernie.
DixieBooker-Lair1
I have been looking for this type of functionality as well.  Has anyone tried using Arcade expressions to write a print function?
AdamBakiera
There is a related post here https://community.esri.com/ideas/11855. The Screening widget works for printing pop-up contents with one minor problem. The widget doesn't like image/graphics fields. So if you don't have those fields or don't need to print them out, you may be able to use that.
BrittanyBurson
It also fails to capture fields written as Arcade expressions in the pop-up -- these export as empty fields. Otherwise it almost works!
