Add Feature Blending to ArcGIS Online
532
01-23-2025 04:27 AM
Status: Open
IB3
I propose adding the "Feature Blend" capability to ArcGIS Online, similar to what is available in ArcGIS Pro. This would allow for more visually appealing and informative maps, particularly for overlapping polygons: https://www.youtube.com/watch?v=BdoLUsj3pEI
Isabelle Breton
2 Comments
EmilyGeo
Hi Isabelle,
Thanks for your idea.
As a work around for now, you may be able to achieve the same effect as you see in the video using blend modes for layers:
1. Create 2 copies of the polygon layer with different fiilters
2. Set the blend mode for the top layer to Multiply.
IB3
Yes, this could work if it was between layers, but I want to blend within
the same layer with a lot of overlaps. I managed to do something with
transparency, but the blend feature give better results.
Thanks for your tip.
