Ability to add Related Records via Item Details Data tab
9313
14
06-16-2016 06:32 AM
Status: Open
MichaelKelly
Occasional Contributor III
The new (June 2016) Data view within the Item Details of Feature Layers is brilliant. An enhancement that could be useful would be to enable adding/removing related table records from the same view.
14 Comments
StevenGonzalez1
I'm still waiting for this functionality.... Any updates....?
JamesWood1
I support this idea. I am going to create related records for each of my existing feature points before I publish because you can edit and existing record. You still can not create a new relationship record for a feature point that does not already have one.
RichmondKyei-Baffour
 I  think a better workflow for further updates is to connect directly to the feature service in ArcGIS Pro, open the related table, and add/remove records there.
Thank you team i have similar challenged and connected to the feature service in ArcGIS Pro to fix that.
...Still waiting for esri to update the AGOL with that functionality in the further update of the AGOL
