Why is my HTTPS secured service not remapped to utility.arcgis.com when I add it to ArcGIS Online?
992
04-25-2017 11:17 AM
by Anonymous User
Not applicable
I am attempting to add a secured HTTPS service to ArcGIS Online with stored credentials.
The issue is that the service is not being remapped to utility.arcgis.com - please see this FAQ for more info. As a result, credentials need to be entered every time the service is accessed in map viewer, web app builder, etc.
I have successfully followed the instructions in Configure HTTPS using a new CA-signed certificate in order to configure HTTPS.
I then open My Content in ArcGIS Online and successfully add the secure service with stored credentials:
However, on the Item Details page, the service has not been remapped:
What may be causing this remapping to fail?
SolomonPulapkura
Occasional Contributor III
Hi Jason,
The site is still unreachable. Best to have your IT folks take a look.
Solomon Pulapkura
https://www.vestra.com/gis
SolomonPulapkura
Is that an internal or external url? You should probably use an external url.
I tried going there but got this...
Solomon Pulapkura
by Anonymous User
Not applicable
It's an external URL but I had the endpoints secured in order to test the secured credentials - you should be able to access that URL (https://test-rtca.cnr.ncsu.edu/arcgis/rest/services) now as I've unlocked the service
SolomonPulapkura
Hi Jason,
Solomon Pulapkura
